200 six manual transmission choice
Posted: Thu Oct 19, 2023 5:46 pm
by gmsnowball
I installed a 200 CI 6 from a 68 Mustang in my 202 Comet. The 202 was an automatic. I have installed the Z bar and pedals so I can install a standard transmission. What transmission would best fit and work? I have a 3 speed manual from a 65 Falcon but I think it may need an overhaul. I also have a 4 speed from a 289 Cyclone but I would like to save it for my Ranchero project. I believe the 200 6 has a 6 bolt pattern. I will need everything from the block back and probably the pilot bushing as well. Any suggestions would be appreciated.
Re: 200 six manual transmission choice
Posted: Fri Oct 20, 2023 10:45 am
by power band
by 1968 your 200
should have the 'dual drilled' bellhouse pattern and FW unique to the later 170/200 small block six.. Providing 200 does have the larger bellhouse pattern, any manual 200 with a "TOPLOADER" 3 speed will have a Bellhouse that can use the strong-all synchro
3.03 Toploader used in all small six and small block non-HiPo cars. The 4 Spd 'Toploader" will fit but Hi=Po Toploaders are different. There are also 'Imposter' 4 speed Toploaders with an Overdrive available which also bolt to 200 six unique bellhouse.
The earlier '2.77 non-synchro 3 speed "peanut" tranny uses a different bellhouse,clutch, FW and linkage.
The later Toploader Bellhouse also accepts later diaphragm 9" clutches for smoother shifts (Fairmont/Mustang etc) .
Toploader 3 speeds - Mustang with floor shifter bosses and Maverick w/o for column 3OTT.
for a huge improvement in
drivability, there are adapter plates available that convert Toploader Bellhouse to accept the 5spd T5 Overdrive transmission. The T5 will bolt right to the 200 Bell - W/Adapter BUT requires some modification and/fabrication.
I use a Maverick 170 (C8DE) and Bellhouse (# C7ZA ) on the '63 Wagon with an adapter plate to a T5 to original 3.50:1 rear.. Rear mount, body crossmember and DS needed some modification. Original Z-bar clutch linkage with slight mod' is used.
I found it strange that my '76 Comet still used the
SMALL PATTERN bellhouse pattern from original 144 Falcon motor for the C4!.
I never learned to drive an automatic...
have fun
Dual drilled bellhouse pattern block.
small bell pattern C4 bell on '76:
Posted: Fri Oct 20, 2023 6:13 pm
by gmsnowball
Great information, thanks. Now all I need to do is find a good top loader 3 or 4 speed that will fit, If none are available I may just stick a C4 back in it. I have already installed the pedals, Z bar, new non auto radiator, new Hurst 3 speed shifter, removed the auto shift collar etc but I could go back with an auto if I have to.
Posted: Thu Oct 26, 2023 5:10 pm
by Joe Travers
gmsnowball wrote: ↑Fri Oct 20, 2023 6:13 pm
You should be able to find a 3.03 Toploader pretty reasonably priced.
Posted: Tue Nov 14, 2023 9:26 pm
by gmsnowball
I have a top loader 4 speed and a 5 bolt bell housing on a built 289 I was saving for another project. Will the 5 bolt bell housing bolt up to the dual bolt pattern 200 ?
Posted: Tue Nov 14, 2023 10:41 pm
by Joe Travers
Rebuild kits and parts aren't that expensive for the 3.03 you already own.
Just a thought....
