Crites spring relocation kit
Just wanted to know if anyone has used the rear leaf spring relocation kit offered thru Crites. With the kit, what is the largest tire you can safely run without rub? Thanks, Russ
1970 Ford Fairlane 500 429scj -drag pack option
1986 Mustang GT, heads, cam, intake, vortech super charger
1964 comet calente -in progress
- juddp39532
Re: Crites spring relocation kit
My 65 has rear springs relocated (Crites kit maybe?) and mini tub. I've had Hoosier 295-20-15 Quicktime DOT about 10" tread on it without rub.
- Spring%20locate2.jpg (58.44 KiB) Viewed 10711 times
Judd;there is a BIG hole in your trunk!!!! Looks like you may be missing a very important part!!!!Aren't leaf springs for buggys?!! ROY.
- juddp39532
Roy that hole is a pressure relief so I don't blow the doors off all the Chevies I pass! Real men have leaf springs front and rear!!!!!!
How stable are the rear leafspring shackles? I was thinking of using their kit on my 63, but i wasn't too sure about the back set-up. They seemed a little weak to me.
1963 Comet S-22 Drag Car
2007 Shelby GT
1989 LX 5.0 Convertible
2007 Shelby GT
- juddp39532
Mine are holdimg up ok but most of the torque on mine is against the ladder bars.
Be careful using Crites products as he sells alot of JUNK stuff!
spike wrote:Be careful using Crites products as he sells alot of JUNK stuff!
as per what? quite a few of us here have used a lot of parts from Crites. what part did you have trouble with or is that a broad statement?
alan
I'M RUNNING 820X15 FIRESTONE CHEATER SLICKS ON 8 IN. WHEELS.....STROKED... NO TUBSeckenber wrote:Just wanted to know if anyone has used the rear leaf spring relocation kit offered thru Crites. With the kit, what is the largest tire you can safely run without rub? Thanks, Russ
Stroked
"Alabama Fan That Bleeds Ford Blue"
http://s1106.photobucket.com/albums/h380/rsbaker/
http://s1106.photobucket.com/albums/h38 ... %20Bronco/
64 Comet BFX Tribute
66 AC Cobra Webers
73 Bronco
66 AC Cobra Webers
73 Bronco
I was looking at the leafspring relocation kit too, but i'm afraid to put it into mr drag car. Looks way to weak for how hard my car comes out. I'm going to make something up on my own.
2007 Shelby GT
2007 Shelby GT
Just got the kit but didn't install yet. Looks cheap in the picture but actually looks like it might work ok. Quality doesn't seem that bad. Only time will tell.
STROKED wrote:I'M RUNNING 820X15 FIRESTONE CHEATER SLICKS ON 8 IN. WHEELS.....STROKED... NO TUBSeckenber wrote:Just wanted to know if anyone has used the rear leaf spring relocation kit offered thru Crites. With the kit, what is the largest tire you can safely run without rub? Thanks, Russ
STROKED, i'm going to get up your way soon and check out that 64. when are you usually around? didn't you say you run a dealership? are you around on saturdays?
YES I AM, I'M HERE SIX DAYS A WEEK. MY DEALERSHIP IS GILBERT-BAKER FORD IN ALBERTVILLE, AL. 35950. GIVE ME A CALL BEFORE YOU COME, MAKE SURE I'M NOT FISHING; 256-891-3000 ASK FOR BAKER....STROKED...riverbum wrote:STROKED wrote:I'M RUNNING 820X15 FIRESTONE CHEATER SLICKS ON 8 IN. WHEELS.....STROKED... NO TUBSeckenber wrote:Just wanted to know if anyone has used the rear leaf spring relocation kit offered thru Crites. With the kit, what is the largest tire you can safely run without rub? Thanks, Russ
Stroked
66 AC Cobra Webers
73 Bronco
66 AC Cobra Webers
73 Bronco
Here is pics of a 64 fairlane that I did.
I usually build my own relocation stuff. Tubing and 1/8"plate are cheap.
Roger
Roger
65 comet 7.61@96mph 1/8
Tweaked65 on instagram
https://youtu.be/JCVwEitXSi4
Crites kit install
