C4 to Toploader
Re: C4 to Toploader
No no no,,That's Skin Head and the Boney Fingers!
Re: C4 to Toploader
Comedians!
Roy Ill be in your neck of the woods next week...if my 65 is road-worthy Ill bring it by. Or Ill phone you for help on the side of the road
Re: C4 to Toploader
Joe;good luck!!!! Give me a call if you have trouble,the stretcher is right next to the monster truck!!!! ROY.
Re: C4 to Toploader
Well finally got the interior back in:
And heres the bottom:
Geez all that work and all you see is a chrome stick and an extra pedal
Now I just need to drive the heck out of it to verify the quality of my work
Re: C4 to Toploader
joe, if you are too busy, you are welcome to drop it off by my house. i will be glad to drive the heck out of it for you and give a written performance report at the end of the month lol
Re: C4 to Toploader
JOE--you did good..looks great...drive the crapp out it,bang them gears,and be grinning like a possum suffering from hung chow...POP
Re: C4 to Toploader
Joe;it looks "Factory Fresh" in there!!! Three Pedal Cars are ALWAYS more fun,of course I'm extremely biased!!!! ROY.
Re: C4 to Toploader
VERY TIDY!!
Re: C4 to Toploader
Haha! Thanks guys!
Ive still got a few issues to work out. Like the console just touches the stick hump and it needs trimming.
Also, (for the mechanical clutch experts); my clutch engages at the very bottom of travel, when it touches the floor. The pedal height is OK (about 1/4" above the brake pedal), free-play is around 3/4". Both my upper rod and lower are adjustable. Any ideas on how to get the dis-engage point higher...to a couple if inches above the floor?
Im thinking of adjusting the pedal stop to get the pedal higher, and then adjusting the upper rod longer keep the z-bar, lower rod and free-play where they are now.
Any thoughts?
Thanks again
Any thoughts?
Thanks again
Re: C4 to Toploader
Joe;adjust your lower rod to put more pressure on the clutch fork,that will bring it up off of the floor. ROY.
Re: C4 to Toploader
OK...so in effect I would be decreasing free play? I tried that and it started acting weird. When I was shifting up at a higher RPM the pedal would return and stop and then pop up at the last 1/4". So I increased the free play a little.CALIFORNIA CALIENTE wrote:Joe;adjust your lower rod to put more pressure on the clutch fork,that will bring it up off of the floor. ROY.
I guess Im gonna get in there and try it again.
This is fun...at least Im not leaking ATF all over the place anymore
Thanks Roy.
Re: C4 to Toploader
My 3 pedal car is a blast.. about a 10 second car...CALIFORNIA CALIENTE wrote: Three Pedal Cars are ALWAYS more fun,of course I'm extremely biased!!!! ROY.
to 45mph..lol
'63 Comet Hardtop
Re: C4 to Toploader
Joe,
Did you adjust the clutch return spring when you put the pedal bracket in? With the pedal completely up the spring length, measured from where it attaches to the clutch pedal to the point on the coiled end that goes through the adjustment rod, should be 10 1/4 inches long. It is adjusted with the nut on the adjustment rod. I don't know if this will help but I adjusted mine before I assembled it. Now, if I ever get the guts to cut the hole in the floor it will be ready to install.
Dave
Dave
Re: C4 to Toploader
Hey Dave,
Im not using any assist spring at all. Im using a diaphragm style clutch and the installation instructions said to leave the spring out...so I did. The clutch pedal effort is light enough I guess. Just to see how it felt I installed the spring and adjusted it and it didnt seem to work as well.
Thanks for the suggestion.
And the offer still stands...have cut-off wheel; will travel
