Ford BW T-10 Help
Ford BW T-10 Help
Any of you Guys real familiar with a 63 T-10.I am converting my 62 to 302/4 speed.I bought a transmission and took it to My local Ford dealership to a friend of mine to go through it.Unfortunately he was diagnosed with leukemia and has had to quit work.So I am trying to put it together myself.I am having trouble putting the tailshaft housing on and the reverse shift fork without the detent ball falling out.Before anyone tells me to go T-5 ,the reason I am using the T-10 is because I am building it the way it would've been built in the late 60s.Any help would be greatly appreciated.Later,Heath
Black 1993 Ford Lightning
- Moderator
as for the ball, pack some trans assembly grease on it and that should get it sticky enough to hold it in place. the tailshaft should go right on if everything is pressed in where it should be. Hope that helps a bit. Good to see that someone is doing it how it would have been done back before I was around. (cookie for you)
Drew Wanzer
"I love the smell of roasting tires in the morning"
The reverse setup is designed slightly different in the 63-65 Warner built transmissions.I have a shop manual for a 67 Ford built,but it is no help.It looks like the spring and detent ball can be installed after the tailshaft housing is installed.You can't do this on the Warner built.
Mike, the BW T-10 will have the inspection plate on the side,a Toploader is on the top.If you manual has the T-10 in it I would appreciate it if you could scan anything that has to do with tailshaft housing and reverse gear assembly.Thanks,Heath
Mike,A friend of mine loaned me a manual and I got it together This week.Hope fully I can get the 302/4speed in this summer.I am taking off work the week of April 10th to do some Turkey hunting and maybe I can get a little done then.Later,Heath
