Comet stuff
All that junk (I mean good stuff) on eBay
Comet stuff
Rally pac
https://www.ebay.com/itm/383923192252
Maverick driver manifold
https://www.ebay.com/itm/303864699145
NOS shifter hump
https://www.ebay.com/itm/254835618011
Not sure why this shift boot is so cheap but here ya go
https://www.ebay.com/itm/143921594073
Re: Comet stuff
comethead wrote:
Fri Jan 29, 2021 11:12 am
Buyer beware. Looks like cheap Mr. Gasket I threw in the garbage recently.
Good repops have the steel ring in the base with predrilled holes, like original.
Re: Comet stuff
I'm sure I'm in the minority, but I never liked those ralley packs. I like the regular old 64 Cylone tach much better. Also they are cheaper and reproduced so that helps.
https://www.macsautoparts.com/cyclone-d ... 160-1.html
Re: Comet stuff
That is a good looking tach! I didn’t know they were being reproduced. Price ain’t bad either.
Not sure why they went to such a small factory tach (and clock and vac gauge) for 65 and 66 :?:
Re: Comet stuff
Fri Jan 29, 2021 2:42 pm
I bought one. I’ll let you know if it’s the steel ringed one or not.
Re: Comet stuff
Did anybody else check out the shifter hump,,
Whoa! Not NOS for a start! Great price if your selling...
Re: Comet stuff
comethead wrote:
Tue Feb 02, 2021 2:48 am
Good luck on your purchase, Joe. I hope it does.
I purchased one from Mr. Gasket, thinking it was correct but no big loss. It was a cheap piece.
Re: Comet stuff
Boss/Cyclone wrote:
Mon Feb 01, 2021 2:40 pm
Cool tach, Boss. No problem burying the needle on that thing. :D
Re: Comet stuff
It's only 6000 rpm tach, I just love that 64 look.
Re: Comet stuff
Boss/Cyclone wrote:
Tue Feb 02, 2021 3:09 pm
No doubt about it. I'd buy one if I owned a Cyclone :wink:
Re: Comet stuff
My opinion is that the ‘64 dash mounted tach is iconic, I wanted to keep the look but as mentioned Boss/Cyclone the tach only goes to 6g’s. I installed Auto Meter gauges in the factory dash panel and found that they offer a small tach in the same series as the gauges so I ordered one, in order to make it look somewhat stock looking I machined an aluminum bezel to adapt the tach to the cup. I also changed the mounting position slightly, instead of facing straight back I angled the tach to face the driver, welded up the holes and redrilled them.
Works perfectly.
‘64 Cyclone/ Boss 302
Re: Comet stuff
Jim, that looks great. I also canted my tach toward the driver. I found an old tach at a swap meet that has that original style with an 8000 tach. This is an old picture, my dash looks better today.
cyclone tach.jpg (116.96 KiB) Viewed 2774 times
Re: Comet stuff
I mounted an old Sun mini-tach in my Cyclone years ago. Wanted a stock one but they weren't reproduced back then. Close as I could get to the real deal. I mounted it in one of the holes in the dash and angled it in as well. Had to tighten it a few times but it hung in there.
Re: Comet stuff
Happy to report it’s one of the good ones! Steel ring, pre-punched holes and nice thick material :D
Re: Comet stuff
comethead wrote:
Thu Feb 04, 2021 11:10 pm
Good deal, Joe! The pic on EBay didn't look right, why I voiced concern.
If it doesn't bind up in 2nd gear (too stiff), you're good to go. Lots of cheap synthetic rubber made these days.
