1965 axles
1965 axles
I'm looking for a driver's side axle for a 8" 65 Comet rearend.
- Site Admin
- Contact:
Re: 1965 axles
I have a pair/set of 8" axles but I don't know what year they are, I was going to put them in my 6 cyl. 8' but I would have to install bigger bearing cups so I just went ahead with the 8.8 instead, I guess I will leave the 8" with 4 bolt wheels and save it for a future project reusing the entire running gear that came out of my '64, don't know what that would be but it is all here, if you can tell me how to ID the axles I might be able to help you out.
Re: 1965 axles
Hello,
Do you have the measurement on the axle you need? Overall Length
Thanks,
Alex
Thanks,
Alex
Re: 1965 axles
I will try to find out the axle length and pistol it. I just know it is the drivers side at this time.
Re: 1965 axles
Mike,
Do you think you can get a measurement on your axle and see if they come close to what I found out.I can't find the paper work from when i bought replacement strange axles which would have had part # and dimensions. i did however find dimensions on Dutchman axles website.
Ford 8″ & 9″ 28 spline rear axle shaft
1964, 1965, 1966 Mustang, 1962, 1963, 1964, 1965 Fairlane, 1964, 1965 Falcon, Comet
Dimensions:
Length, LH drivers side: 26″
Length, RH passenger side: 30 1/8″
Spline count: 28
Bolt pattern: 5 on 4 1/2″
Stud size: 1/2″
Brakes: Drum
Drum pilot: 2.432 (1/4” tall, stock height pilots carry a $ surcharge)
Wheel Bearing: Ball, RW207, 2.835 od
Retainer Plates: Yes, SB-SB
OEM Part #, LH: C2OZ-4234-A, C5OZ-4234-A
OEM Part #, RH: C2OZ-4235-B, C5OZ-4234-B
Dimensions:
Spline count: 28
Stud size: 1/2″
Brakes: Drum
Re: 1965 axles
Mike,
If you still have those axles, here are some pics on how to measure them. I have the long axle and I am looking for the short 26" axle.
- Attachments
- axle 2.JPG (106.37 KiB) Viewed 177 times
- axle 1.JPG (107.54 KiB) Viewed 177 times
- axle 3.JPG (111.73 KiB) Viewed 177 times
- Site Admin
- Contact:
Re: 1965 axles
I actually completely forgot to check sorry, thanks for saying something, I will try and check them this week.
Re: 1965 axles
No worries, I finally myself had the chance to measure the axle i have.
- Site Admin
- Contact:
Re: 1965 axles
Got these measured hopefully these pictures will make sense, if you need to see something better or I need to measure something else, let me know
I measured all the lengths with the tape hooked to the face of the hub
Short Axle
Long Axle
& hub
Short Axle
Long Axle
& hub
Re: 1965 axles
Thanks for the pics. I sent you a PM.
