I am new to the comet world. I bought a 1963 that I am building into a gasser . The car came with a 351w and a 4spd, neither were installed.
I am looking for the clutch assembly from the pedal to the fork. I think other year comet setups will work? You guys would know that better then me I'm sure. I need more parts but want to get the clutch set up done first.
So please. If you are parting a car or just happen to have an old setup around please contact me. I would also welcome any suggestions and or advice from anyone that has done a V8 conversation.
Thank you,
Donn
Clutch parts and more wanted
Re: Clutch parts and more wanted
I have complete 4spd conversion from parted 64 but I am not sure it will work ?????
I'm not sure, but I'm definitely interested. I'm going to start a thread and see if anyone here knows and also do some research myself
I'll write back to you later,
Thank you,
Donn
Thank you,
Donn
The engine compartment's look the same, I'm still researching . How much are you asking?
Thanks
Donn
Thanks
Donn
Pretty sure the 64 parts will work in a 63.
The only issue I can see would be the z-bar width. You may have to modify it because of the difference in the 289 and 351 blocks.
Also 64 bellhousings were 5 bolt and 351 is a 6 bolt pattern.
email me at b.flood@myactv.netEconodonn wrote:The engine compartment's look the same, I'm still researching . How much are you asking?
Thanks
Donn
Found a complete setup from a guy on the Hawb for $200.
Don, I have completed a couple V8 conversions. Give me a call or e-mail me. Mark 610-248-3257 merc383@aol.com
1963 Comet S-22 Drag Car
2007 Shelby GT
1989 LX 5.0 Convertible
2007 Shelby GT
Joe;unless the 289 is an early one,351W and 289-302 all are the same from deck down,motor mounts,bellhousings,front dress,starter,pan is different as a 351W uses bigger mains!! ROY.
