Spare Tire Jack for '64 Comet
I am in search for a spare tire jack for my 1964 Comet. Also the lug wrench would be good. Thanks.
Re: Spare Tire Jack for '64 Comet
well you know it's a bumper jack,,,even tho they were use for yrs,they aren't really safe....so what I do..is use a small scissior jack under the axle and barely clear the ground with the tire,then I use bumper jack to just lift body just enough to get tire and whl off the rear... frt will lift with scissior,, I also do the same thing on my 1966 f100 pu on the rear,,,so I carry both jacks in each..the rear whls are wide on the trk..good luck on your hunt....POP
