I WANT TO FIND OUT WHAT TYPE OF ENGINE I GOT THE NUMBERS I GOT OFF THE BLOC ARE DBBE AND UNDERNEATH THAT IS 6015GC AND NEXT TO IT THEIR IS A FORD STAMP WITH A TF22 UNDERNEATH I WANT TO KNOW WHAT TYPE OF ENGINE I GOT BEFORE I START BUYING AND DOING ANY THING TO IT AND DOES ANYONE HAVE THE EXACT WIRING DIAGRAM FOR A 1961 COMET BUILT IN DECEMBER 12 1961 IN SAN JOSE
MY ENGINE WAS SWAPPED
ENGINE BLOCK NUMBER PLEASE HELP TO INDENTIFY MY ENGINE
- Contact:
Cali Comet loving ROCKER
It is a 6 I would guess?
The easiest way to identify a 200 cid is the freeze plugs on the right (passenger) side of the block - 200=5 plugs, 144/170=3 plugs.
Depending what you have most parts are interchangeable on the small 6's.
The best 6 is the 200 cid because it has 7 main bearings the others only 5 but all of the I6 engines are actually pretty good motors.
I will look around for the numbers, unless someone else knows and see what I can find for you.
- Contact:
okay cool thanks
honestly i dont know where that is the freeze plug let me find out do u think those aluminum intake manifolds wor great
The freeze plugs are round plugs around an 1 1/2" where the water jacket core was held in place when the motor was cast, they run down the passenger side of the block under your exhaust manifold.
5 means a 200 cid.
yes I like my Offy intake but it takes some tweaking to get it set-up right. I would really like an aluminum head from Classic Inlines but haven't had the money to sink into it.
5 means a 200 cid.
- Contact:
thanks
thanks mike yeah i was looking at it at intae manifolds but imight just a new carb first then the manifold
