Gasket for heater spacer on carb 144 6
I have the carb to intake manifold gasket that mounts above the heater spacer but the one beneath it that sits directly on the manifold>I need that one. It looks more like a heat type gasket and is thicker. Where do I find one? This is for the 144 6 cylinder. Thanks.
Re: Gasket for heater spacer on carb 144 6
Thanks, I'll give them a try!
FYI Gasket for heater spacer on carb 144 6
Nope....wrong gasket. Called Fel-Pro. Gasket no longer available. You have to make your own using Fel-Pro number 2499.
