Too Rich For Me
Posted: Wed Oct 23, 2024 5:58 pm
My 200-6 started running rough; wouldn't idle at all. Checking it out, all six plugs (pretty new; 5 months, less than 2,000 miles) were completely fouled black. Put another new set on (NGK WR5) and engine started running great again.
Another clue is I've been getting really crappy MPG, <10 MPG.
Not sure that this is related, but I've been having auto-choke trouble where the bimetallic coil never moves the choke full-stroke. If I set it open when hot, it doesn't close when cold; if I set it closed when cold, it doesn't open all the way when hot. I've been leaving it open because of that.
But the MPG and fouled plugs are my real problem.
How could the air/fuel mixture be so rich? I fine-tuned the idle mixture screw back when the plugs were new. I have timing about 12ยบ BTDC. Just took the carburetor apart to see what main jet is in it: it's a 66. From what I understand, the stock jet for sea level is the next size bigger (67). I ran unleaded reg (87) for a while, but for the last couple months I've using 90 Octane Ethanol-free.
I've read that the harmonic balancer can get off on these and throw off your timing marks. Anyone know of this? Would WAY high BTDC cause my issue?
