I took my right rear quarter window out to replace the rollors & inistall front weather seal. Also got to put a nut on the top trim strip while window was out. Cleaned & greased regulator while apart.
Can't get the 2 rollers into window slots.
Install order: regulator, small track in back, long track in front, window. All mounting nuts left loose
got the roller in small track in back & bottom window roller in long track.
Got the front regulator roller in front window track, Can't get back roller aligned with opening in back slot. Tried cranking reg in all positions.
Tried removing small track with no luck
Tried outting back roller in 1st with no luck
Is there an assembly order for getting the window back in?
Haven't removed the left window yet
Gene
Reinstalling Quarter Windows 63 Comet Convertible
Re: Reinstalling Quarter Windows 63 Comet Convertible
I got the winidow back in today by removing more parts from window.
Will write up what I did when I get it adjusted.
