Fuel Pump Switch Location
Posted: Wed Aug 19, 2020 8:50 am
Opinions wanted.
I have a fuel pump switch to cut power manually for whatever reason. Would you put the switch showing on the console or place it up under the dash where you can't see it while sitting in the seat (my thoughts would be right below the ignition switch, where you could reach down and flip it on)?
I have an LED light with a little gas pump on it I thought I would wire to the switch to show the switch was on and the fuel pump is running so you know the power is going to the pump in case you forget the direction the switch goes to turn it on.
