Rustoleum Turbo Paint
Think this is really cool! Wide fan to cover large panels.
Available in rusty metal primer as well for those rashy rat rod jobs.
https://www.youtube.com/watch?v=N1mcKg435wc
power band
Re: Rustoleum Turbo Paint
Post by power band »
... I thought it meant paint for your turbo - between the Turbo RO rattle can and spray plastic coatings the world of amateur paint possibilities keeps expanding beyond paint roller jobs..
'74 Comet/Maverick has alternate hood and cowl sprayed with flat black plastic - @ 2 years and still ok:
(SC plumbing didn't fit under original Grabber stripe hood so used alternate with scoop on Comet hood. )
painted turbo on 170 :
power band wrote:
Tue Jun 15, 2021 12:17 pm
Cool Mav! Had an old girlfriend drove a Comet GT and another friend a Mav 6 banger back in the 70's. The Rustoleum wide fan Turbo comes in clear if you wanted to top off the hood for ultra-shine. Just wondering how durable but the hood looks good.
I got concerned with durability of 1k rust oleum that is why I decided to switch to a 2k single stage on my hood I read any paint that uses a catylist will resist gas and bird droppings over a one part, non-catylist type paint. There is a cost involved and you need equipment to apply with the paint costing 2x 3x more, I did mix enamel hardner wth the rust oleum I painted on the hood but will be sanding that down for a coat of epoxy sealer and single stage paint.
see Ya,
mike
power band
Quality Single Stage paint can provide the lacquer like luster and overall smooth color often missing even on expensive BC/CC paint. The important post-paint care needed prevents it's wider use by novices and in repair shops.
'the 61 has PPG DP primer and PPG DBC Single Stage 'Wimbledon / Corinthian/etc ' long standard Ford off white. My very novice paint shoot still had enough of build for a careful wet sand cut and a final buff for satisfactory finish results. I found out you paint the car once but sand - off the original paint, the plastic/fbgls filler and the hi-build primer, wet sand, repeat, repeat...,
. Image . Image
