Page 1 of 8
Finally decided to cut my shock towers.
Posted: Mon Jul 02, 2012 6:40 pm
by Boss/Cyclone
Re: Finally decided to cut my shock towers.
Posted: Mon Jul 02, 2012 9:42 pm
by 383MERC
Good decision buddy! I can't tell you how happy i am since i did mine over the winter. Your going to wonder why you waited so long. Looking good so far. Keep us up to date. Oh, one other thing. While your at it, do yourself a favor and cut out the center rib below where your cutting now. I cut it back and plated it in on a gradual slope downward. It may give you more clearance down low for headers. Mark
Posted: Mon Jul 02, 2012 10:08 pm
by Boss/Cyclone
Mark, I used the thread you started earlier this year as inspiration. I am too old to get those header bolts in now, I need the extra space.
Posted: Mon Jul 02, 2012 10:55 pm
by SASSY
Welcome to the cut up car club!!
Posted: Tue Jul 03, 2012 12:49 am
by CALIFORNIA CALIENTE
Cut up car club,my 65 is PURE STOCK!!!!! ROY.
Posted: Tue Jul 03, 2012 7:23 am
by 383MERC
Your really going to enjoy the extra space to change the plugs too. My fat little hands need all the room i can get. HAHA
Posted: Tue Jul 03, 2012 9:59 am
by Boss/Cyclone
I am going to remove the welded in export brace today. Is there an easy way? Should I drill out the spot welds and then fill the holes in, or chisel and grind it off?
Posted: Tue Jul 03, 2012 10:28 am
by SASSY
Torch, just squint and you won't even need eye protection
Posted: Tue Jul 03, 2012 10:46 am
by Boss/Cyclone
SASSY wrote:Torch, just squint and you won't even need eye protection
Thanks for that great advice, I think I will pass on that though.
Posted: Tue Jul 03, 2012 12:40 pm
Larry;I ground the ends at the towers to where I could break them free after I used a sawsall to cut them at the firewall pinch weld.The only welding was then to just close up the end of the pinch weld,mainly just for looks as it is spot welded from the factory.I use adjustable braces from MPG in Colorado. ROY.
Posted: Tue Jul 03, 2012 1:05 pm
by Boss/Cyclone
CALIFORNIA CALIENTE wrote:Larry;I ground the ends at the towers to where I could break them free after I used a sawsall to cut them at the firewall pinch weld.The only welding was then to just close up the end of the pinch weld,mainly just for looks as it is spot welded from the factory.I use adjustable braces from MPG in Colorado. ROY.
Thanks Roy, I figure with all the experience and knowledge on here is was better to ask for a good idea rather than to just start hacking away.
Posted: Tue Jul 03, 2012 3:17 pm
by 383MERC
I cut mine off as close as i could and then ground them smooth. I too used the adj brace kit like Roy did. I couldn't get my valve covers over the stud girdles without removing the braces. I was kind of forced into it, but i like it a lot. Mark
Posted: Tue Jul 03, 2012 3:40 pm
by Boss/Cyclone
Posted: Tue Jul 03, 2012 5:42 pm
Larry;that is a very nice looking brace setup,looks plenty strong too!!! ROY.
Posted: Tue Jul 03, 2012 9:06 pm
by SASSY
So,,,,,,,? Did anyone else notice the FE headers under the car?
Thought you were into Cs
