Page 6 of 8
Re: Finally decided to cut my shock towers.
Posted: Thu May 30, 2013 8:23 am
by 383MERC
Looking good buddy! Can't wait to see that FE in there. Gotta start saving up some sheckles myself for the Fairlane's FE. I got a std bore 428CJ block and a beautiful tunnel wedge intake so far. Now i have to learn a whole new engine family. Your going to love being able to pull those bars out for doing valves etc. It makes everything so much easier. Mark
Posted: Thu May 30, 2013 10:13 am
by SASSY
So I'm lovin the Coilovers, tubular contol arms and the drum brakes
Kinda protour stocker?
Hey,,just ribbin ya, great work
Posted: Thu May 30, 2013 11:48 am
by CALIFORNIA CALIENTE
Larry;nice looking suspension!! I hope you are going to put disc brakes up front!!! ROY.
Posted: Thu May 30, 2013 4:14 pm
by Boss/Cyclone
Yes, disc brakes are coming soon.
I need to get the car off the lift so I can work on my Mustang. So drums are back on for now.
Posted: Thu Jun 06, 2013 8:22 pm
by Boss/Cyclone
She is back together and is a roller. Need to do brakes and put in drivetrain.
Posted: Thu Jun 06, 2013 8:42 pm
by Boss/Cyclone
Also, needs alignment and I need to install hood trim that I got on E-bay last year. Oh well, one day it may be done. No engine in it for now.
Posted: Thu Jun 06, 2013 9:00 pm
Mean stance Boss! I guess it will come down in the front with a drivetrain. How big of a tire can you run? You moved your rails in or something didnt you? looks great!!
Posted: Thu Jun 06, 2013 9:08 pm
by Boss/Cyclone
poboyjo65 wrote:Mean stance Boss! I guess it will come down in the front with a drivetrain. How big of a tire can you run? You moved your rails in or something didnt you? looks great!!
It won't drop alot. Shawn (owner of Street or Track) custom build the Bilstein shocks with my coil over suspension for the weight of a FE. I sat an old 390 in there earlier today to see and the front dropped down about 1/2 and inch. Yes rear frame rails are moved in. I have 325-50-15's Hoosier quicktimes on the back now. Had some 28-11.50 slicks on there before and had plenty of room.
Posted: Sat Oct 31, 2015 8:58 am
by Boss/Cyclone
After sitting the engine in I decided to rethink my work. I did not like the stance, as the front had dropped to low with the engine in for the look I was after. I had lowered the upper control arms one inch, now decided to lower them another inch for a total of two.
Here is the new holes drilled out below the already lowered holes.
I was looking for a good high front end stance, so I also needed to lower the lower control arm mounts. Used the street or track adjustable lower mount kit and moved them down 3/4 of an inch. This lifts my whole front end for the stance I want with out overly taxing the ball joints and steering geometry.
Here are the pucks that slide in to set the alignment.
Then after lowering a second inch, recut the towers and welded in patches.
Here is the stance now, with 351C sitting in to give it some weight. I wanted the high front end look, so I think it was worth the extra work.
Posted: Sat Oct 31, 2015 2:41 pm
by Boss/Cyclone
Also, I pulled the pedal assembly to adapted the Mustang Steve clutch cable setup. Should have that stuff in a week or so.
Posted: Sat Oct 31, 2015 2:44 pm
Good to hear your still working on it.
how's the wagon coming??
Posted: Sat Oct 31, 2015 3:40 pm
by Boss/Cyclone
I don't get much time, but the wagon is coming along. Held up waiting for my rack and pinion conversion kit so I started working on the Cyclone. Thanks for asking.
Posted: Tue Apr 19, 2016 8:55 pm
by Boss/Cyclone
Posted: Wed Apr 20, 2016 10:54 am
Larry,I like the new wheels!A lot of work to get the front end UP where you like it!351C staying for now? Roy.
Posted: Wed Apr 20, 2016 11:31 am
OK That's what it is,,,new wheels! I couldn't put a finger on it but I knew something was different. I thought it was the florescent lights making the blue paint look purple
they look good!
