Let me start!!!!!!!!
StPro
Re: Let me start!!!!!!!!
Post by StPro »
So do you have the rear suspension carriage for the IRS? Is it Mark VIII or T Bird? Mark VIII had all aluminum lower control arms with air bags and aluminum center section. I took mine out of my Black Mark VIIII. I was putting in a 9" ford with ladder bars and coil overs. I know I still have some parts lying around.
Projects
65 Comet 421Stroker
70 Torino GT
I have the parts I need but thanks much for the thought
At the moment my plan is tubular arms and sub structure.
Mounted to the front leaf spring mounts and frame up in arch
so the car can be reverted to the 9 inch.
FRP composite mono leaf Vette rear leaf spring, shocks?
Challenge is I want it 50 inches mount face to mount face!
I want to maintain present wheels, appearance.
Hoping for 3 inches bump travel but the cv boots will be about touching each other so I have to build at least one side shortened halfshaft and test range of movement.
Mission bc 09/12 (I think)
Roy, Brian n me
StPro
Post by StPro »
I remember when the Cobras with IRS were drag racing and breaking CV shafts there were several companies selling shafts any length you wanted. That was my biggest concern racing the Mark VIII was breaking half shafts. The Mark VIII would only run low 12's. I was afraid that if I put in a high stall converter with a trans break I would need stock in an axle company. Found out the shafts in the Lincoln were smaller so they could twist without breaking.
Projects
65 Comet 421Stroker
70 Torino GT
Ya if I had big power and was drag racing I wouldn't be building an IRS. But 210ish hp and no intetest in going drag racing with it, should be fine. IRS in the Comet is just about being different.
Roy, Brian n me
