I have a medium and a light spring in mine, not sure why yours is coming in at a higher rpm then mine one thing I heard from the guy at AED was that they have seen some issues running two light springs said that they had a few that would hang up and not return to base timing properly so if you have any strange things you might keep that in mind.Comechero65 wrote:Sounds like you are in the ball park on the dist advance. Maybe hitting max advance just a little too soon at 2500. How many deg is that mechanical and what is your intitial timing set at.
When I set mine up I used the two lightest springs in the set I have which gave me a max of 21* mechanical advance. Used the 13* notch on the advance piece. Set my timing at 14*. I have 21 * mechanical advance so with the 14 * intial max advance comes in at 35* advance at 2800 rpm.
I'm also running lean at cruise so I need to up the pri jet sizes one size or two to get it off of dead lean.
I wouldn't go any higher than a 6.5" on the power valve. 10 sounds to high as it will be opening way too soon, i think. If yours is wet on the back side either the diaphragm is leaking or the gasket is leaking fuel by. Should be completely dry on the back side.
Looks like you are getting it dialed in.
My initial is 16 with a total of 36 starts great and seems to be pretty snappy but I need dry roads to know for sure.
thanks
Ant
