Autolite 4100 manual choke kit
jtgb428
Post by jtgb428 »
Hey guys, quite a few years ago there was a manual choke kit on ebay for the autolite 4100, you had to do this and that and modify this and modify that on the carburetor.....this setup from what I understand was basically junk...is there finally a manual hand choke setup you can bolt on and go with no hitches..I have a 4100 I would like to run on my 289 and would really like the manual hand choke setup..didn't the 271 hipos have this setup..I'm currently running a edelbrock 500 cfm 4bbl and it works real good but when I had the 4100 on my 289 there was no comparison the 289 really sang...I just had the 4100 rebuilt and want to run a manual hand choke..thanks, Jim jtgb428..
Re: Autolite 4100 manual choke kit
Some HiPo 289s had automatic chokes. Are you running exhaust manifolds to provide heat tube to the choke?
If so, I would leave it and adjust it properly.........or tune the Edelbrock properly.
No reason the Edelbrock couldn't sing as well or better.
jtgb428
Post by jtgb428 »
I have headers..don't know if it's just me but the 289 seemed to run stronger with the 4100..it came off of a big block with the 1.12 ventures and was calibrated to run on the 289..really would like the hand choke...thanks, Jim...
Why not do an electric choke ? the one I'm using on my 4100 works good.
jtgb428
Post by jtgb428 »
Jim here, how do you like the electric choke? Have you had any issues with it? Seems easy enough to install...I'm not much of a mechanic but I think I can install your setup no problem... I looked it up and am pretty impressed... Thanks, Jim...
I have a manual choke on my 4100. I bought the kit off eBay. It screws onto the holes where the auto choke mounts like the original.
You have to change the choke plate link for it to work. I found a choke plate shaft with the right link for $7 instead of staking the one from the kit.
Also you have to plug the auto choke vacuum hole. I used epoxy.
Once adjusted correctly it’s worry free.
