Stumped - 63 comet 302 Accelerator linkage
Re: Stumped - 63 comet 302 Accelerator linkage
McComet1963 wrote:
Fri Mar 19, 2021 1:13 pm
FYI, I am going with a cable system and new pedal from Lokar... Thanks for all the help and suggestions.
Probably best.
Old bellcrank pivot rod wears against bracket over time, can get a little sloppy.
McComet1963
Post by McComet1963 »
Engine run tho... No drive shaft or differential yet...
Starting to work on that today
tweaked
Post by tweaked »
I used a cable from a granada. Simple install.
Roger
65 comet 7.61@96mph 1/8
Tweaked65 on instagram
https://youtu.be/JCVwEitXSi4
McComet1963
Thanks... I got er done with a cable from Lowkar... Test and Tune pix is nice!
