New Fuel Pump
harleyddad
New Fuel Pump
Post by harleyddad »
Fuel pump went out on my 65 289 Caliente. Went to Summit to get a Carter M4009 unit, but Summit says I need the top mounted filter unit. Not the low mounted filter. Car currently has a 66 289 pump with a in-line filter..Which one is correct?
Rootsy
Re: New Fuel Pump
Post by Rootsy »
M4009 is appropriate and fine.
harleyddad
Re: New Fuel Pump
Thanks for the reply, ordered the M4009.
Re: New Fuel Pump
I agree with Rootsy, shouldn’t matter, plumb it and go.
Re: New Fuel Pump
harleyddad wrote:
Mon Jun 17, 2024 6:54 pm
Weird they recommended the top mount filter. I believe that’s for the I6 engines not 289.
harleyddad
Re: New Fuel Pump
Well, I finally got the Carter M4009 and plumbed. It took a few minutes to get fuel to the carb, had a slight kink in the inlet hose that replaced the in-line filter that was used on the previous pump.
Now to fix the exhaust/header leak and break loose the brake cylinders, I might be able to put this ole girl back on the road.
It never does a car well to let them sit up for any extended time period, I'm learning that the hard way.
Thanks again for the input.
Re: New Fuel Pump
harleyddad wrote:
Mon Jun 24, 2024 4:21 pm
I drive mine at least once a month for 30 minutes to keep everything lubed up.
harleyddad
Re: New Fuel Pump
Between covid and medical issues I have been on limited duty, but is over now, every thing in the shop is getting a little attention now, until I fall out again.
Re: New Fuel Pump
harleyddad wrote:
Mon Jun 24, 2024 5:04 pm
I hear ya, brother. I'm crippled, blind and crazy but my Comet stays lubed up! :wink:
Wishing you the best
