289 - 302
ken81
289 - 302
Post by ken81 »
hi I am restoring a 1961 comet and looking to put a v8 in it and would like to know if any year 302 or 289 will bolt right in and where is a good place to find parts for my comet and a motor thanks
bmmaurer
Re: 289 - 302
Post by bmmaurer »
I am presently removing a V-8 260 and Auto trans from my '63. Engine will need a rebuild because of a tap and trans has low miles on a full rebuild. Let me know if interested.
Bruce
Here's a before and after picture
bmmaurer
Re: 289 - 302
Post by bmmaurer »
Where you located?
bmmaurer
Re: 289 - 302
Post by bmmaurer »
Also, a 6 cylinder trans will not work with a V-8 tranny...
ken81
Re: 289 - 302
Post by ken81 »
I am in upstate ny and I don't have the original motor or tranny I plane on putting a 302 and a c4 trany & 9inch rear in it just need to know out of what year mustang will all of that will just bolt up to my 61 comet thanks
Re: 289 - 302
ken81 wrote:will all of that will just bolt up to my 61 comet thanks
The quick answer to that is none as far as I know, there is going to be some kind of modification required because 61 Comets never had a V8 in them, someone can probably give you the information for the easiest way to do it but the early Comets have smaller engine bay than the Mustangs.
Sorry I can not be more help than that but I have never done anything remotely like you want to do, but I am sure it is very doable.
Performance rebuild on a BUDGET - Installed; 250-6, T-5, 8.8 LSD, MII, Air Ride - Boxes are too restrictive I would much rather think outside of them :wink:
Re: 289 - 302
anything is doable...in the hot rod world....but is it really worth it ?? jmo....pop....what's wrong with a neat 6cyl,,that never gives any problems,,,turn the key and it performs like a clock....at my age and lookin back,,trust me when I ask,,,WHY ? but the hot rodder in me from yrs ago ,,,I see were your coming from....on asking ….POP
bmmaurer
Re: 289 - 302
Post by bmmaurer »
[quote="ken81"]hi I am restoring a 1961 comet and looking to put a v8 in it and would like to know if any year 302 or 289 will bolt right in...
To answer this question simply... No
