1963 S22 V8 347 engine/trans swap questions...
McComet1963
Re: 1963 S22 V8 347 engine/trans swap questions...
Post by McComet1963 »
at flywheel...
Haven't had my engine on dyno but close to you.
Haven't broken my 8". Running 8" BFG T/A radial 60s, not enough traction to break it.
McComet1963 wrote:
Fri Feb 26, 2021 11:37 am
Installing 347 because I have one from days gone by...
new 5 speed
~ 390 hp and 350 torque.
original 8" hold up to this??
Me and my son was at the local drag strip handful of yrs ago,,,there was a guy raceing his fox body stang,,,it was a SVO,those cam with 2.3 4cyl,,this guy had a 460 c6 in it,,,but it still had the 4lug 7.5 rear end under it,,didn;t have much tire,,he ran it all day and then drove it home....so how tough is a ford rear end?? no matter what size rear gear!!
McComet1963
Interesting.... Would like to try my 63 comet rear for a year to make sure all else is ok and maybe work on some stuff while I drive it.
Thanks for the feedback...
I have a 1984 mecury capri for over 20yrs,,it is a factory 5.0 5spd,but it came with that small 7.5 rear gear limited slip with a 3.23 ratio 4lug..before I went to a 8.8 3.73 LS ,,,I tried to tear that rear end up,,I didn't care,,,I burnt more rubber ,I dogged the fire out of it...I never tore that rear end up..I ordered from ford a complet brand new motorsport 8,8 3.73 LS and houseing less axles and installed it,,but I used the very same axles from the 7.5 that was factory installed and they are still in it....motor heads clutch headers shifter msd ign you name it has been since changed,,I ran it on the street ,drag strip. sticky tires ,,but those 4 lug axles are still in it....and I have the aftermarket traction devices under it,,OL POP has been meaning to post this for awhile,,,just now thought of it...good luck to all....POP
McComet1963
Since my last question I learned my inline 6 conversion has a 7" rear end.
My friend told me this would probably not get me out of the driveway is I was lucky...
So my next question is what rear ratio rear gears do you guy have and are you happy with it.
I have T5 trans and 347 with a cam rating 1800 - 6000 wherever tires I can put in the rear.
Right now they are 24.66 in height 185/80 13... Obviously I will have to get new rims and tires.
My guess is 3.89 will cover me for easy round town and long trip driving...
McComet1963 wrote:
Sun Feb 28, 2021 6:58 pm
It'll get you out of the driveway. The rest depends on how you drive the car.
If you plan on dumping the clutch at 6K with cheater slicks............. :roll:
