Cut V8 motor mounts
Posted: Fri Feb 26, 2021 11:52 am
by McComet1963
Wanting to keep the headers from rubbing on the manual steering box.
Options are to cut about 1/4 in mounting hole on both mounts hopefully to shift the hearing away from running.
Anyone ever do this?
Re: Cut V8 motor mounts
Posted: Fri Feb 26, 2021 12:25 pm
by McComet1963
Ok so I got an answer from Modern Drive = NO
I will however dimple the headers fit...
Also the headers are wrapped and I am told this will void the warranty and destroy the headers from the inside...
Anybody running uncoated headers? Shorty's from Sanderson.
How's the heat under the hood?
Posted: Fri Feb 26, 2021 5:31 pm
can you space the engine up higher,,just enuff to help with clearance,,or new mounts,,maybe yours are old and flattened somewhat....transmission mount also.....pop
