351 windsor in a 65
351 windsor in a 65
Does anybody know if a 351w will fit in a 65 comet without a lot of major changes? Will it hit the shock towers? Will factory exhaust manifolds work or would I need custom shorty headers? I'm not committed to anything yet ,just tossing around some ideas. I'm thinking about using the gt40p heads if that makes any difference.Anybody have any experience with this?photos? thanks Cecil
- Moderator
- 65CycloneFTW
- Contact:
It will fit. There is a lot of discussion on this modification at Comet-List, and you can get headers at Crites, along with other parts to help with this install.
http://autos.groups.yahoo.com/group/Comet-List/
http://www.critesrestoration.com/comet.htm
Tough times dont last, but tough people do.
- Moderator
351W in 65 Comet
The 351 fits well.A good friend has been running this combo for 15 years!He had custom headers built,but other than that it bolts in.If you use Gt40 heads on any small block you will have header problems with spark plugs,.I run a 347 stroker,makes plenty of power without the weight penalty of a 351.There are two deck height 351s,9.2"&9.5,289&302 are 8.2".I hope this helps.Roy.
- Moderator
- Moderator
351W in Comet
The only difference is 9.2"verses 9.5",You can hardly tell the difference.Edelbrock lists two different manifolds for each deck height but I have been running an early performer on a late block for over 200,000 miles!You DO NOT have to shave the towers to put a 351 in your Comet,it helps but is not necessary.Roy.
- Comet Central Member
GT40 heads shouldn't be a problem, as far as the spark plug angle go they are the same as any other stock small block head. The GT40-P heads ( off the explorers ) have a spark plug angle that is different than any other ford head. finding headers for the "P" heads will be a problem.
1964 Mercury Comet Caliente 2-door hardtop
1966 Ford Galaxie 7 liter Convertible ( Under construction
1937 Ford Tu-dor Street Rod ( Dad's car )
2003 Ford F-250 Crew Cab Lariat
