347/475
Re: 347/475
Late model four bolt damper or early three bolt damper? I use STOCK 60s parts on mine as it is a 60s style three bolt damper! ROY
Real Racecars have 3 pedals
Re: 347/475
Nothing like the sound of a pushrod V8 singing at the top of her lung's.
Re: 347/475
ME TOO....shift that sucker JUST before she blows,,,,,,and a ford sounds the best,,when my son was 16yrso,I had built him a 67 fst back stang,,289 4spd,he would put a battary operated tape recorder in the pass seat,at the drag strip,just before he took off he hit the on button,,back at the pits he played it back and would listen to the motor,you would be surprised what he learned just by listening to the shift points,,,,he was 10 yrs old when I built the car and today he is 47 and still has it.........popLip Ripper wrote:Nothing like the sound of a pushrod V8 singing at the top of her lung's.
Re: 347/475
Great story Pop.
Re: 347/475
Roy, its a new Professinal Products Dampener. It has multiple threaded holes. Not sure if its universal to a 3 and 4 bolt pulley. Jim
Re: 347/475
Jim, put one on my late model 302. My early model 3 bolt pulley bolted up to it. The guy at the store said it would work with either style of pulleys, Pugs.
302 roller
4 speed
4 speed
Re: 347/475
Jim I am using the brackets & pulleys from a mid 70s pick up. it actually puts the alt. higher & more closer to the motor. the whole motor,timing cover,w pump,ps pump, everything is from the truck. I have an aftermarket damper on another 302 & it has both 3 & 4 bolt patterns, yours looks to have both too.
