Need some info
Tudelum48
Need some info
Post by Tudelum48 »
I have had an issue with a 260 I'm trying to resurrect. I had a low oil pressure issue.
When I checked I had a broken push rod and the lifter had popped out of its slot.
Will this cause low oil pressure?
CALIFORNIA CALIENTE
Re: Need some info
Post by CALIFORNIA CALIENTE »
Yes,it will as you have an oil galley running down each lifter side.If a lifter comes out you have about a 3/8" hole where oil will escape! ROY.
