no spark
no spark
i haven't got to drive my comet lately.after fixing the clutch linkage and it sat for about a year,i fired it up to see if the pedal felt ok,ran good but the next time i tried to crank it it would not fire up.it burned a hole in the rotor tip and melted the button in the dist cap.after replacing the cap and rotor im not getting a spark.it had rust in the dist is what caused the problem.the box or coil has conked out.
fryedaddy
Re: no spark
well my box quit on me,that makes 2 in the last 3 or 4 years. i went a different route this time,i left the box off and put a 20 dollar gm module in it.for some reason its way more responsive than it was with the box on it,revs like a small block.and i had to back the timing down 3 or 4 degree after switching to the module, very happy with it.
fryedaddy
- Boss/Cyclone
- Site Admin
Re: no spark
What ignition were you running? Duraspark? I just bought a GM module to build a replacement for my duraspark in my Bronco II.
Re: no spark
it was all msd till i put the module on it.i dont have a rev limiter now that i got rid of the box,but thats ok,i didnt need it anyway
fryedaddy
Re: no spark
MSD used to rebuild failed boxes but I don't know anymore.
Looked for the schematic online but couldn't find it.
Re: no spark
i think im done with those boxes,i ran a malory duel point for 18 years,no problems,didnt even change or reset the points in it.switched to msd dist and box and had 2 boxes go bad in 4 or 5 years.if the module holds up good im done with the boxes,plus its snappier and it idles right away when cranking cold start with the module.
fryedaddy
Re: no spark
MSD =fryedaddy wrote: ↑Wed Jul 05, 2023 1:07 pmi think im done with those boxes,i ran a malory duel point for 18 years,no problems,didnt even change or reset the points in it.switched to msd dist and box and had 2 boxes go bad in 4 or 5 years.if the module holds up good im done with the boxes,plus its snappier and it idles right away when cranking cold start with the module.
Projects
65 Comet 421Stroker
70 Torino GT
Projects
65 Comet 421Stroker
70 Torino GT
Re: no spark
Never owned an MSD and they must've been good at one time but I don't even read posts from people supporting them when negative feedback comes along
Re: no spark
My '63 runs MSD. No problems since I bought it three years ago. The 6A control box was rebuilt some time in the past. Probably because some dip installed it under the overflow reservoir on the inner fender well. I moved the reservoir after I pulled the A/C dryer.
I love their distributors. Only takes a few minutes to tune.
Re: no spark
For sure no spark issues with the module.this thing is flying.running better than it ever has period! HAPPY!!! Its no street outlaw but its not bad for me.
fryedaddy
