Header recommendation for 390
Posted: Wed Jan 07, 2015 2:17 pm
by jdhank
Well, I've pretty much decided to put the original 390 "S" motor back in my '67, instead of the 4V Cleveland I had planned on, saving the Cleveland for my future '65 some day.
Anyhow, I'm surprised at the price on headers on the usual online vendors...they're much prouder of them than the small block headers I was looking at for the Cleveland.
Anyhow, any recommendations on Brands or Vendors? BTW, I'm cutting out the oe shock-towers and putting a Rod & Custom coil-over front suspension in it so I'll have a bunch more room to fit them in.
Tks!
Re: Header recommendation for 390
Posted: Wed Jan 07, 2015 2:59 pm
by Lip Ripper
I love my FPA's. The others all drag the pavement. And if you're running the GT heads you need the headers made for them. They are not cheap but they are great. Here is a clip I made after installing mine.
http://youtu.be/Iu4hz0HkgE4
Posted: Wed Jan 07, 2015 5:09 pm
GREAT job,STACY,,,looks good !!!!! POP
Posted: Wed Jan 07, 2015 10:52 pm
by ENOLCYC
Lip Ripper wrote:I love my FPA's. The others all drag the pavement. And if you're running the GT heads you need the headers made for them. They are not cheap but they are great. Here is a clip I made after installing mine.
You definitely have a very clean car!
I looked at the FPA website at the headers they don't list a price? If you don't mind how much are they?
Posted: Thu Jan 08, 2015 12:37 am
by CALIFORNIA CALIENTE
You will most likely need headers made for that front suspension swap,along with an oil pan made for an FE to clear the crossmember and steering rack! ROY.
Posted: Thu Jan 08, 2015 4:55 am
by jdhank
That's a sweet ride 'Ripper, I love your car.
Now you have me wondering if I have GT heads or not? I had them rebuilt last year with new springs, Valve guides, and hardened seats & then ground the valves. I haven't installed the heads on the motor yet (motor's still in pieces) as I put it on hold after I got the Cleveland and started rebuilding it.
How do yo tell if they're 390 GT heads? It is an "S" code car and my assumption is that motor is original.
Jd
Posted: Thu Jan 08, 2015 6:20 am
by Lip Ripper
Thanks for the compliments and Roy those are good points.
The ceramic coated headers are around $900 shipped I think. Stan at FPA can answer the questions Roy posed.
The GT heads have a lowered exhaust port on the front and rear of the heads. If you take a straight edge across the top bolt holes of the exhaust ports the front and rear port bolt holes will be lower than the two in the middle by about a quarter inch.
Posted: Thu Jan 08, 2015 1:26 pm
by ENOLCYC
Lip Ripper wrote:Thanks for the compliments and Roy those are good points.
The ceramic coated headers at we around $900 shipped I think. Stan at FPA can answer the questions Roy posed.
Thank you. Not bad considering they are already ceramic coated. Is the fit good? Do you have pics of that? I will be installing with a 4sp the Web site said there would be some mods to the linkage.
Posted: Thu Jan 08, 2015 1:36 pm
by Lip Ripper
The fit is very very good. I did have to take the cut off wheel and cut a very small relief on the side of one torque box flange. You know, the little wings that stick out to the side on the bottom. Nothing structural. I am running the C6. I have read that it is easier to install them on the engine then drop it in. They hug the engine that tight. I just looked and I don't have any pictures of them in the car. It would be hard to see them anyway.
Posted: Thu Jan 08, 2015 5:46 pm
by ENOLCYC
Thanks. I do have a set of the stock GT exh and the 428 cj exh just never liked how the tube headers hung down so low as my car is very low. Now I'm considering the FPA headers.
Posted: Thu Jan 08, 2015 8:47 pm
by fairlaniac
Posted: Thu Jan 08, 2015 8:54 pm
by fairlaniac
Here is a CAD drawing I made of the 4 speed linkage. It may be hard to see but on the 2nd from left image you can see the end of the z-bar is in red line. I cut off 7/16" as it was hitting one header tube. I relocated the pin by drilling a new hole and plug welded the pin. It didn't change the ratio of the z-bar too much and did not affect operation.
Posted: Fri Jan 09, 2015 10:53 pm
by ENOLCYC
Thanks for the input. It's funny I like my power steering we'll see what happens there.
Posted: Sat Jan 10, 2015 6:23 am
by Lip Ripper
I don't have a boot on mine.
Posted: Sat Jan 10, 2015 8:34 am
by fairlaniac
Lip Ripper wrote:I don't have a boot on mine.
I ran mine without the boot after it melted but eventually the heat on the rod affected the seal in the ram cylinder and it started to leak. Then it was time for manual steering.
