help decoding Canadian tags needed
rhead63s22
Post by rhead63s22 »
So, looking at my (Canadian) car, I have the following tags to decode:
Door data tag: 1AA 938 MK 578200 R76B 63L
On the right passenger fender ??? 76B 63L (rest obscured by a repair - will soon uncover)
On the rear interior convertible panel 76A C3DB 763101? from Canadian Automotive Trim Division, Ajax, Ontario
on the rad support 7 9 6
3 9 1 7 9
1AA 938 MK S
76804 R76B L
Anyone able to decode all of this for me?
Re: help decoding Canadian tags needed
These are all the references I have. They're a mixture of US/Canadian info and models. I can match some numbers, but others I can't. You can look them over and see if they help.
http://www.mercurystuff.com/1963-comet- ... ation.html
http://www.tpocr.com/lincolnvin3.html
http://www.mercurystuff.com/1963-galaxi ... adian.html
There is also a forum member called bmmaurer who has a beautiful 63 S-22 vert that should prove a fount of info for you. Try PMing him, if he doesn't chime in here first.
http://www.cometcentral.com/forum/membe ... file&u=832
Good luck,
JIm
15x7x3.75BS TTII's all around
347, 4sp, 9'' 215/60/15 - 295/50/15
rhead63s22
Well, can decode castilian GoldS22 convertible. No idea what 938 or Mk stands for. 578200 seems to be the production serial number.
rhead63s22
having no luck decoding......
I tried plugging your information into the link that Poboy listed above, but it wouldn't work. Don't know what to tell you. :?
