63 Convertible seats HELP!!!
GERK
Post by GERK »
I am not really having a hard time sourcing most of my needed parts.
I am however stuck with the seats.
1963 Comet Convertible s22
The rear seat is just rusty springs that break when you touch the seat
The fronts are pretty much the same. Just slightly better.
Has anyone had this issue?
Where do I get seats? The upholstery seems easy to locate. Just not the bases and springs.
Are there any other cars that will work? Besides possibly a falcon?
Thanks all
rhead63s22
Re: 63 Convertible seats HELP!!!
Post by rhead63s22 »
Falcon seat are the same...
bmmaurer
Post by bmmaurer »
Early Mustang buckets should also be very close
bmmaurer wrote:Early Mustang buckets should also be very close
bolt spacing is a little different, you'd need to drill new holes,probably 3 on each seat.or make adapters. but they would fit just fine in the car. but comet upholstery may not fit.
347, 4sp, 9'' 215/60/15 - 295/50/15
Bagger
Post by Bagger »
rhead63s22 wrote:Falcon seat are the same...
So ideally, I can buy the replacement Falcon foam for my Comet? Or possibly Mustang seat foam?
bmmaurer
Post by bmmaurer »
bmmaurer
Post by bmmaurer »
I used falcon foam with slight modifications.
Comet Bruce
bmmaurer wrote:http://www.cometcentral.com/forum/viewt ... 15&t=15922
These will work.
Comet Bruce
Those may be for a hardtop which are different than convertible seats. tracks are different & they sit higher (hardtop seats).
Bagger
Post by Bagger »
bmmaurer wrote:I used falcon foam with slight modifications.
Comet Bruce
What kind of modifications?
Lip Ripper
Post by Lip Ripper »
And the Stang seats have a much lower profile.
bmmaurer
Post by bmmaurer »
The foam in this area needed to be cut to be narrower across the top edge to accommodate a different thickness of the area.
Bruce
Bagger
Post by Bagger »
bmmaurer wrote:The foam in this area needed to be cut to be narrower across the top edge to accommodate a different thickness of the area.
Bruce
Gorgeous car! Can I ask what pieces of your interior needed replaced and how hard they were to obtain or where you got them?
bmmaurer
Post by bmmaurer »
Dash Pad replacement from Just Dashes... http://www.justdashes.com/
NOS seat covers and Repo Door Panels, seat foam from Jake at https://www.falconcometinteriors.com/
Carpet form ACC
Comet Bruce
