Has anyone run across a choke cable that enables the use of the stock knob? I guess I could take a stab at ordering a universal one and hope it mates up. Just don't want to use the cheap plastic knobs that come with those and try to keep stock appearance. I have a dummy knob held in place with a narrow screw now, as my car came equipped with automatic choke. Thanks!
Manual Choke Cable
Re: Manual Choke Cable
Joe,Joe Travers wrote: ↑Tue Jul 20, 2021 12:24 amHas anyone run across a choke cable that enables the use of the stock knob? I guess I could take a stab at ordering a universal one and hope it mates up. Just don't want to use the cheap plastic knobs that come with those and try to keep stock appearance. I have a dummy knob held in place with a narrow screw now, as my car came equipped with automatic choke. Thanks!
I have used a universal cable from NAPA for many applications.https://www.napaonline.com/en/p/BK_S672 ... KjcnBszQ8i
Sometimes the knob is threaded on and sometimes it is molded, I usually remove the knob then install a factory knob from the cigarette lighter in the choke cable end. For a trim washer I have used an original manual choke trim washer which is very rare or a washer from the headlight switch. (I machine off the “Headlight” logo then have the washer chromed)
The blue arrow points to the choke:
Thanks, Jim! NAPA is my source of choice. Fifteen bucks isn't a deal-breaker if it won't thread on.A/FX wrote: ↑Tue Jul 20, 2021 4:28 amI have used a universal cable from NAPA for many applications.https://www.napaonline.com/en/p/BK_S672 ... KjcnBszQ8i
May have to get highly innovative on this one to make it work out the way I want.
Thank you, John but those are made for the knobs w/ set screw like the Mustang. Mine is threaded on the '63.
Really like the bezels, though. I need one of them as well, as my car didn't include one with the dummy knob.
Ok ,misunderstood you reading about the dummy knob. tap & die set? lol
Are yours the white knobs?
No, those are the Falcon knobs. Merc is chrome. High-end stuff
Thanks for this post.
My generic aftermarket cable is seized. This will look original and it doesn’t need to be unfrozen!
