hello again!!!
hello again!!!
Got past my last problems. ready for the extended running of the engine at idle. mechanical fuel pump seemed to have good suction when moved by hand. gas was drained and replaced. wiring is correct. about to do initial oil change. any precautions? should I plan on replacing the oil pump to be safe. not sure how long its set up, but sounded fine when cranked recently. any advice would be appreciated. wish me luck.
