Joe Travers wrote: ↑Mon Jan 18, 2021 11:17 am
Have any idea what compression ratio you have now?
Not sure, the machinist said someplace in the mid to high 9s we cut the dishes bigger in the tops of the pistons to keep from going too high because I wanted it to run on a common pump gas if we would have left them stock it would have been in the 10s, if I was doing it over I would have had him get California emission pistons and saved myself the expense of having him machine the piston tops but I wasn't thinking when we were selecting pistons ( I ended up with a piston near the spec of the CA piston but it cost me more
, live and learn) I think I have 12cc dish and the CA pistons are a 13cc dish.
The Tempo connecting rods were near the perfect length at around an 1/8" longer than the 250 rods (the 86-91 Tempo 2.5L HSC motor was a 250-6 or possibly a high deck 200 with two cylinders lopped off basically, take 4.1L/6 and then that number X 4 and you get 2.73333L or 2.5L probably with good math
either way, it was made from the basic Ford I6 and the connecting rods fit a 250 I believe they are even forged units) I did have to use Tempo rod bearings because they changed the shape, the crank journal is the same size (I believe the main bearings might be SBF bearings but did test that one out).
I had suspected the FE pushrods were the same because the rocker arms look near identical to the old 144 adjustable rockers in the solid lifter motors, I even wonder if they interchange but I am not going to experiment now, the problem with the 250 pushrods are they never came with adjustable rockers so all of them are ball & ball rods and the 200 ball and cup pushrods are too short, the FE ones were near the perfect length (fortunately) so I did not have to get custom length pushrods made $$$ and got to buy cheaper stock 390 pushrods $ with adjustable rockers they work fine once I actually got them set correctly
(initially I had them too tight and with hydraulic lifters that is not required because, as we know, they are supposed to self adjust. Most of the stuff was found by looking through a bunch of specs and looking at pictures plus getting a little confirmation over at the Ford6 forum. Lifters were all the same on the little sixes as FE motors so I was able to get some better FE lifters and put them in there. It does appear that Ford used many interchangeable parts and why wouldn't they? I think they should have made even more things out of the same parts (and maybe they did, I am no expert on anything) the only original part of that junkyard 250 is the block and crank the replacement parts are almost nothing that was made for a 250 (water pump & oil pump are 250 replacements) I suspect there are some other things like timing gear sets that interchange as well but just went with an early ('69) replacement set because Ford had not started retarding the timing sets as badly as they did in the '70s (the cam also has 4 deg. advance built into it)
I am pretty happy I have had few total goofs on setting this motor up (and that is why I am amazed it runs), it is hard finding too much info on doing this that is why I try and post everything to help anyone that follows along behind me I can tell them what worked for me, it is still their chore to actually find some of the rarer parts but I guess that is part of the challenge
