Got out and tried to fix my fuel gauge issue, I did indeed run out of gas because i drained around a gallon and half of fuel out of the tank, which was about what I put in there when it ran out, I pulled the sending unit, bent on the float arm a little and then reinstalled the unit only to have a good stream of gas leaking out around it when I put gas back in
I think I was getting a similar reading with no gas, I would think 4 gallons should move it up a little above E? It is not that big of deal I guess, if the car hits empty there is still 4 gallons of gas.
Anyone have a tip for installing the sender unit? Am I going to have to pull the tank just to get it back in leak free (like it was before)? I have a second gasket and lock ring around someplace but not sure that would help because it is impossible to hold the gasket in place and insert the unit.
Right now there is a bucket sitting under there catching the drip but tomorrow I will probably drain the gas back out and dump it back in the can until I can get the leak stopped.
