I'm putting a '65 type headliner in my '64. I recently picked up 3 bows and still need the fourth. Two that I have look identical and the third is longer with a little bit different bent ends. Are three of the bows identical and a unique fourth? I just need to figure out which one I still need as I'll be posting a "Wanted" ad soon.
Thanks,
Question on wire type headliner bows
- fairlaniac
Doug Bender
1964 Comet Caliente
1966 Fairlane 427/4 Spd
1964 Comet Caliente
Re: Question on wire type headliner bows
Doug;I sent you a Message on FB.Here is what I found,the two front ones are the same,should be Black,The third one is Blue,fourth is Red,should be installed BEFORE front and rear glass as the rubber holds it in place! ROY.
