loman wrote:
Thanks Fred. By the way, what did you put on top of your seams when you were done? I was planning on seam filler or panel adhesive. I think I remember reading that Lou likes to use the panel adhesive and I like what he has done on his car.
Yes, I used panel adhesive to seal all my seams. Seen seam sealer shrink, lift and found rust under some of the factory seam sealer when I removed it. It is more money but IMO the best results.
Wire brush the seam real good, clean with wax/grease precleaner, put the adhesive on right over the bare metal. I use a acid tin brush to work it into the seam real good and to finish it. After it sets paint over it, I used epoxy primer over it.
If you want to use seam sealer, I use SEM on customer stuff , but I don't use it on bare metal, i epoxy primer the metal first then do the seam sealer. Use the same tin brushes. I can get you the part # for the SEM seam sealer tomorrow if you like. It works pretty good but have seen it shrink.
