c6 trans
smithhe
c6 trans
Post by smithhe »
has anyone swapped a c6 into a 64 comet? I know its longer than the c4 by a couple inches but I don't know if there was crossmember out there for sale or if I would have to fab one
vicegrip
Re: c6 trans
Post by vicegrip »
Have a c6 in a 65,big block. Motor is back to the firewall for radiator concerns and had to do some minor sectioning of the hump but nothing serious. Got a cross member from Dark Horse performance in Washington that worked perfect but they might be out of business. What motor?
smithhe
Re: c6 trans
Post by smithhe »
347 stroker
vicegrip
Re: c6 trans
Post by vicegrip »
Grab a small block C6.very dependable and strong trans.Easy to work on.In your case,you might not have to do anything to the tunnel. Cut the ears off the side of the bell before install.Not needed and always in the way for exhaust.Try to find a case with no ribs on the top for more clearance.
