FUEL LINKAGE
FUEL LINKAGE
Has anyone used either LOKAR or other less expensive brands accelerator pedals in their COMETS or FALCONS? I have a very nice lokar cable set up from my carb to the pedal. The pedal I scrounged from a 72 TORINO and it works fairy well, however I can't get enough throttle travel to engage the secondaries. I have a 65 CYCLONE with a 289 4spd Any thoughts?? THANKS. TOM
Re: FUEL LINKAGE
I recently used a lokar cable setup in a old truck. Had the same problem secondaries wouldn't open, pedal didn't have enough travel, was hitting floor before opening the secondaries. I shortened the cable. Raised the pedal a little but did the trick. I remember thinking I would need to buy new shorter cable but then seen one end of the cable came apart and you could cut the cable and cable housing to fit application.
Re: FUEL LINKAGE
We used a LOKAR "knock off" from Speedway in Ole Rusty. With proper pedal indexing and cable adjustment it works great and a lot cheaper.
