Hi All,
I own a 64 with a 260 .
My question is; Are all water pumps turn in the same direction ?
Water Pump Rotation
- fairlaniac
Re: Water Pump Rotation
The small block Ford water pumps on the 80's version of the 5.0 has reverse rotation to accommodate the serpentine belt system.
Doug Bender
1964 Comet Caliente
1966 Fairlane 427/4 Spd
1964 Comet Caliente
in 1984,my factory 5.0 mercury capri,,water pump did not turn in reverse and it had a serpentine belt..might have been the only year,,I found that out when I replaced the water pump.....I"ve had this old mercury close to 25 yrs,and I still have it !!popfairlaniac wrote:The small block Ford water pumps on the 80's version of the 5.0 has reverse rotation to accommodate the serpentine belt system.
question, if I put a early style water pump on an 85 302 that comes stock with a reverse rotation, and I run it without a serpentine, just use some v belts like the early models, will it work? I bought an early style water pump for my new engine build (85 5.0) and it bolts right up and everything but I just want to make sure its not going to mess anything up by not being reverse rotation.
Serpentine setups were available in standard or reverse. Easy to tell by looking at the pulley. Smooth pulley = reverse rotation, ribbed = standard.
Don't try to run a reverse rotation pump backwards, it won't work very well, if it will even bolt up, which I doubt it would. You need the timing cover to match your pump.
