Cool can't wait to see it run, it is such a cool project and all looks super good.smithhe wrote: ↑Tue Oct 27, 2020 7:10 amI am finally starting to see the light at the end of the tunnel! Only things left is to connect the new 2/0 battery cables I just finished , mount and wire the switch panel, and fill up all the fluids! I will try to get a video of the first startup to put on here.
I did not comment on the trans mount, did you end up making your own? On my T5 mount, I made the new part that connects to the original frame mounts and then modified the T5 mount by narrowing it. I may still redo it because it hangs so low but it also protects the bottom of the trans some because it is the first thing to hit the ground and is heavy enough to hold the car up
