Another Aussie 64 Comet Build
Re: Another Aussie 64 Comet Build
Been a little while since I posted but things are moving along. Steering Rack Mounted
Power steering reservoir and hard lines
- Attachments
- 6BF62EE8-20FA-4C81-8005-E0F12F8A41C0.jpeg (52.28 KiB) Viewed 2709 times
Custom fuel tank
you do such top notch work,,your attention to detail puts your work over the top....very nice...take care,john....pop
Chassis Connectors, Fuel Hard Lines, Trans Cooler mounted and plumbed.
Trunk floor was modified to make way for the upper shock mounts.
Diff housing mocked up in place
6mm Bizalloy plate was lazer cut using mdf templates. This was used to plate up the chassis rails and for the upper arms to mount to. The lower arms were sunk into the chassis rails.
Great fab work!!!
You the MAN!
You the MAN!
Beautiful craftsmanship!
What is the vacuum diaphragm and cylinder in the trunk for?
Wow! you aussies do top notch work,are you aussiejohn's kin? !
are the tires on the right sides? looks like rotation is wrong ? Of course I do realize this is mock up stage & they're coming back off but i had to speak up.
I appreciate the design, fabrication, and welding, very well done. Please keep the updates (and photos) coming.
