front left calliper leak
Re: front left calliper leak
anybody knows what caliper this is? Maybe I should just replace both fronts. I'm sure I would have to replace the spindle.
thanks here is a pic of the spindle
Sassy said Granada so I looked up granada and it's possible 1979. I checked with Rock Auto and it looks like the same Caliper. Not sure if I want to replace it or just rebuild it. My rotor doesn't look to good either. I'm going to order the two front replacements as I'm sure the passenger side is no better.
Very good time to consider 65 spindles brakes and all.
Complete kits available, basically early Mustang stuff so
will be around forever.
I guess basically I don't see any wrong with the Granada stuff, basically pretty inexpensive and you probably will not ever change them out again most likely, unless you drive it a lot.
Has to be cheaper than a kit to fix what you have, but I don't like spending my money
wife's 56 ford has Granada stuff,,been there over 20 yrs...never the 1st problem..with dot 5 fluid,,,,pop
Well guys, he's taking about replacing calipers and rotors, will end up doing the bearings and a tierod and balljoint or two,,, so add a pair of spindles and get the correct geometery too. Plus its Mustang it'll be around for ever and easy to get. Was my thinking on it.
