Door hinge question
Door hinge question
It appears that I have to replace the lower door hinges on my 65 comet. Can anyone say if 65 Mustang ones will interchange as I am finding nothing specific to complete 65 comet door hinges.
Re: Door hinge question
Are you sure you need to replace the whole hinge? Is it broken? If it's just wobbly, you can replace the bushing and hinge pins to tighten it up.
https://www.macsautoparts.com/ford_falc ... ge&x=0&y=0
Yes both bottom hinges are damaged. I discovered it when I was taking them apart to install the rebuild kits I have on the shelf. Thanks but I need rebuildable cores or new hinges. DR
Jims65cyclone wrote: ↑Sun Aug 09, 2020 7:50 pmAre you sure you need to replace the whole hinge? Is it broken? If it's just wobbly, you can replace the bushing and hinge pins to tighten it up.
probably way late as I haven't been on for a while .definitely a no on the Mustang hinges . I know I have a new set from Scott Drake sitting on my book shelf
Thanks, I got lucky and picked up a set of NOS hinges on ebay. Never been on a car.
