64 T-5 Tranny swap
Benny
64 T-5 Tranny swap
Post by Benny »
Hello All
I recently bought a T-5 transmission to bolt onto my 289. I'm almost ready to yank the stock 260 & 3 speed tranny out. My question is will this 5 speed fit without a lot of hacking.... ??
Re: 64 T-5 Tranny swap
Benny wrote:
Sun Oct 18, 2020 1:42 am
Hello All
Benny someone will come along with a definitive answer soon but a few things they will want to know is what the T5 came from and what is the bolt pattern on the 289, I am not sure if the 289 can be a 5 or 6 bolt motor, I think most modern bell housings are 6 bolt and if that is what you have then it should be a fairly straight forward swap.
Anyway, you will need to have the information on hand at a minimum.
A 5bolt BH takes the narrow bolt pattern.....if your tranny does not have both sets of holes per ear...you have a problem...I have a T5 in my 84 5.0 capri but it's been so many yrs since we built it,I can't recall if it has both holes on it or not......pop
redhotcomet
Post by redhotcomet »
If you use a Mustang T5 like I did, you’ll have to cut a hole for the shifter and there is a cross brace under the floor there. Plenty of people have cut it without trouble. The shifter location is good with bucket seats. If you have a bench you way want to use an S10 tailshaft which moves the shifter ahead. Other than that you will need a trans support crossmember. I built my own.
barrys65cyclone
Post by barrys65cyclone »
they do make a tail housing for T5 trans for the forward mounted shifter to put in correct location I saw one in 1964 Cyclone
barrys65cyclone wrote:
Sat Nov 07, 2020 7:55 am
The forward-mounted shifter position is a tail shaft housing from an S10 T5.
