Page 14 of 29
Re: Doug's 65 Cyclone build
Posted: Sun Jul 11, 2021 9:26 pm
by Jims65cyclone
DesertRat wrote: ↑Sun Jul 11, 2021 2:34 pm
One of the biggest things I have found to be beneficial is building a spreadsheet on everything I buy for the car.
My brother from another mother!!
I have several.
Posted: Sat Jul 24, 2021 9:37 am
by DesertRat
My rear firewall project. I made a template from cardboard and transferred it to 16 GA steel plate.
I painted the cutout plate with a coat of epoxy primer and a coat of single stage with a brush, I didn't want to clean the gun for a small job.
Here is the installed plate ready for seam sealer.
This brings me to the "down to bare metal" stage. I am taking the outside original paint off and with my DA I am sanding it down to bare metal.
I think I know a place that will dip the doors, fenders, hood and trunk lids so I don't have to sand that old paint off. I will talk to them Monday.
Posted: Sat Jul 24, 2021 10:41 am
by SASSY
Hey Doug looks good.
That panel may rattle either by itself or against the seat springs. ,,,,Been there when I drag raced mine with a rear firewall similiar to yours.
Just a thought.
Posted: Sat Jul 24, 2021 12:02 pm
by DesertRat
Thanks Fred: I did an aluminum one in the blue 404. This one I will seam seal all around and contact cement some closed cell foam to it for sound deadener. It will never see a track so it is just for safety and comfort. It is amazing how tight it makes the interior of the car, I like it.
Douglas----------------
Posted: Sat Jul 24, 2021 12:43 pm
by Jims65cyclone
Don't ever lock your keys in the trunk.
Posted: Sat Jul 31, 2021 4:20 pm
by DesertRat
It's 95 to 105 degrees by noon here every day dammit. I'm sanding my car down to bare metal so it's start by 7:00 AM and quit by noon.
So far it has been all DA and 60 grit but I have some abrasive wheels coming from Eastwood.
I was going to dip the doors and other parts but decided against it. It will be all hand prep-------------
Hoping to have the body on primer next weekend but we'll see------------------
DR
Posted: Sat Jul 31, 2021 10:52 pm
by Joe Travers
Looking good, Doug. Yes, in the house by Noon here as well.
How is the humidity?
Posted: Sun Aug 22, 2021 6:41 pm
by DesertRat
In the process of sanding the car to bare metal I find the drivers door has an old repair that doesn't meet specs. I would like to buy a left side Comet 2D HT door or a new door skin. I have given a cursory look and haven't found anything. Can anyone help with this?
Douglas---------------will a 1964Comet door work?
Posted: Sun Aug 22, 2021 7:36 pm
by Lou's Comet
DesertRat wrote: ↑Sun Aug 22, 2021 6:41 pm
Pretty sure a 1964 Comet door will work. Actually think 64-65 comets and Falcons share the same doors, given the same models. Hardtop to hardtop, sedan to sedan.
Posted: Sun Aug 22, 2021 9:47 pm
by A/FX
A
‘64 & ‘65 Comets and Falcons of the same body style share the same doors, although the trim mounting holes may differ.
Posted: Mon Aug 23, 2021 12:05 am
by DesertRat
Thanks for the information guys. I will dig deeper for a new door. I think I can buy a 65 falcon 2D hardtop door from one of the usual suspects.
Douglas
Posted: Mon Aug 23, 2021 12:56 am
by Joe Travers
DesertRat wrote: ↑Mon Aug 23, 2021 12:05 am
As Jim mentioned, the Falcon has a wide side molding covering the center body line, unlike the Cyclone. Going to have to plug those trim mounting holes with welds and do a bit of grinding. Might be a bit tough getting some copper backing behind the skin. Check out Comethead Joe's track Falcon. You can see the mounting holes above and below the trim line.
Posted: Mon Aug 23, 2021 8:49 am
Yea 64 & 65 falcon have trim holes in the cove as well as 64 caliente.65 caliente has a set of trim holes at the bottom & top of door for rocker & beltline moulding. so 64 & 65 cyclone is you best donor with no trim holes to fill.
Posted: Mon Aug 30, 2021 4:00 pm
by DesertRat
I have been working on my Comet as often as I can. Here are some photos of my quest to get the car down to bare metal and sealed with epoxy primer and sandable primer. The first photo is the car ready for wipe down and epoxy primer.
The second photo is me painting in my driveway hoping the wind doesn't come up.
The third photo is the car sunday after spraying the epoxy primer.
The fourth photo is this morning after getting about 100 ounces of high build sandable primer on the car.
I am using Eastwood abrasive discs to strip the paint off all the body parts and start from bare metal. It is a grueling nasty dirty dangerous job but it is the only way I can see to get the car where I want it.
Posted: Mon Aug 30, 2021 9:29 pm
by Jims65cyclone
Lookin' good! With all this going on in front of your house, I'm surprised some neighborhood child entrepreneur hasn't set up a lemonade stand, some folding chairs and started charging admission to watch.
