So how much positive caster do you guys shoot for? Right now I have 4.125 degrees and .125 degrees negative camber. The car drives like a dream so I'm quite happy with it, but I'm going to be redoing the front suspension and will have to realign it. I'm going to a coil over shock and I want to raise the front 1"
tom
Shelby drop
Re: Shelby drop
THAT'S where I remember it from! No wonder I couldn't find it in the threads. I'll go back through our PM's.
Disclaimer: Just celebrated another birthday. More brain cells lost.
Re: Shelby drop
Do you have any idea on how many are left?Jims65cyclone wrote: ↑Sun Feb 07, 2021 12:18 amDisclaimer: Just celebrated another birthday. More brain cells lost
I really don't need any my wife pretty much reminds me of everything I have or have not done
Re: Shelby drop
Ya but she wouldn't remember what type or size fasteners hold the gas tank in,,, I don't think. LOLlavron wrote: ↑Sun Feb 07, 2021 2:26 amDo you have any idea on how many are left?Jims65cyclone wrote: ↑Sun Feb 07, 2021 12:18 amDisclaimer: Just celebrated another birthday. More brain cells lost
Priorities!
Re: Shelby drop
all you can get Tom! 4 I wish I could have got 4!!tomb22 wrote: ↑Sat Feb 06, 2021 10:53 pmSo how much positive caster do you guys shoot for? Right now I have 4.125 degrees and .125 degrees negative camber. The car drives like a dream so I'm quite happy with it, but I'm going to be redoing the front suspension and will have to realign it. I'm going to a coil over shock and I want to raise the front 1"
tom
Re: Shelby drop
Do you think there is a problem with having the shim stacks more than 9/16" which I have and I know I have more than 1/32" difference between them. I used a breaker bar to tighten the 3/4" bolts up. The one problem I had was the grease fitting on the side of the upper a arm began to hit the shock tower so I drilled a hole thru the shock tower to alleviate that.
tom
tom
Re: Shelby drop
I did a far amount of PMs with a guy on the old TFFN who ran a strong beauty built 63 Falcon hardtop in time attack. Pretty sure he said his car was happiest at 7-9° positive on track.
Im somewhere 7-8° never wrote it down,, forget. The EPS is now useful and the castor returns it to center.
Re: Shelby drop
Tom, although your shim stack is probably ok, have you considered adjustable strut rods?
I sloted the front hole on the lower Aarm mount to allow the lower to go further forward. Once happy with the position I tacked a washer over the hole and locked down the nut.
Some pics to study.
https://cometcentral.com/photos/album/eCCU
Some pics to study.
Re: Shelby drop
SASSY wrote: ↑Sun Feb 07, 2021 3:17 pmTom, although your shim stack is probably ok, have you considered adjustable strut rods?
When I aligned the car I was looking for 4 degrees caster and I achieved it so I was satisfied and to me it drives really well. I know I don't have much clearance with the front wheels in front to the fender, but I could always get a smaller diameter tire. I went back and read your post on your steering and saw what you have done and accomplished. Very impressive. I'll see where I'm at with my new coil overs and maybe I'll have to go down some of the roads you did.
tom
