1964 Comet Steering Column Blues.
joswald
Post by joswald »
Howdy. I have a 1964 Comet with the gear selector on the column. The problem is the selector can come out of gear just by pulling the gear selector. There doesn't seem to be anything holding the selector in gear. A can this be fixed? B if not what are my options?
Re: 1964 Comet Steering Column Blues.
anything almost can be fixed, and,,sounds like you have worn parts,,,how's the pin that holds the lever to the collar and also the collar it's self..can you grip the shaft and pull up or shove down ?? is there a gap under steering whl ?
