Dash backlighting
Dash backlighting
The dash instruments on my 65 are difficult, at best, to read at night even with the gain up to full tilt boogie……I know I saw a thread here about replacing the bulbs. Can someone give me some direction?
Jack Bartelt
1965 Comet Caliente Convertible
Re: Dash backlighting
remove light diffuser and install LED bulbs color of your choice.
Ah, another Wisconsin member! Welcome!
Try watching this.....
https://www.facebook.com/groups/1132914 ... 548924172/
That’s what I was seeking……Thank you gents!
Can I get some direction as to an LED bulb part number and source?
Jack Bartelt
I have purchased quite a bit from:Racersonly wrote: ↑Fri Aug 06, 2021 12:02 amThat’s what I was seeking……Thank you gents!
https://www.superbrightleds.com/
They have a very informative web site.
Sorry to be a bit late to this.
I also used Superbrightleds.com for my 65 Caliente. Their site is remarkably complete - they even had the bulb for the green lighted compass indicator behind the column PNRDL window.
However I ran into a problem on the gauge lights. I wanted to keep my blue cans (the diffusers)... but the bulb they recommend was too long for the diffuser cans. When I pressed the socket I to the hole the bulb would press up against the can... and the bulb would separate from the ground (sometimes even causing a short). I had to use a lower profile shaped bulb I got off Amazon.
Note that I followed the Superbrightleds.com recommendation to use bulbs the same color as their corresponding lenses. So for the gauges with blue diffuser cans I used blue bulbs, for dash signal indicators behind free windows I used green, for front parking/signal lights I used amber, etc. This worked quite well - every thing is nice and bright and my gauges are well lit (could be brighter but much better than original).
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
kevin
I also used Superbrightleds.com for my 65 Caliente. Their site is remarkably complete - they even had the bulb for the green lighted compass indicator behind the A/T column PNRDL window.
However I ran into a problem on the gauge lights. I wanted to keep my blue cans (the diffusers)... but the bulb they recommend was too long for the diffuser cans. When I pressed the socket I to the hole the bulb would press up against the can... and the bulb would separate from the ground (sometimes even causing a short). I had to use a lower profile shaped bulb I got off Amazon. That was the only recommendation Superbrightleds.com made that failed to work for me - everything else was correct.
Note that I followed the Superbrightleds.com recommendation to use bulbs the same color as their corresponding lenses. So for the gauges with blue diffuser cans I used blue bulbs, for dash signal indicators behind green windows I used green bulbs, for front parking/signal lights I used amber bulbs, etc. This worked quite well - every thing is nice and bright and my gauges are well lit (could be brighter but much better than original).
Thanks,
kevin
kevin
I used Mustang Project for my LED backlighting.
10 years later still going strong
https://www.mustangproject.com/Catalog. ... cd65560ffb
Just finished my backlighting project. I’m pleased so far. (Now to go out for an evening cruise)
Jack Bartelt
