The 1965 convertible hydraulic cylinders do not attach to the floorplan; rather they swing freely on a pivot/bushings at the top of the cylinder.
Am I correct that the intended design (Ford Engineering) was for the cylinders to swing into the oblong hole within the upper sheet metal component “Gusset (Floor Side Member to Wheelhouse) Upper” (MPC 103A18-9)? (See below picture/illustration(s)).
Has anyone had success in getting the cylinders to swing freely into those gusset slots (vs. binding on either side of the gussets)?
1965 Convertible Cylinder Swing Behavior
- Untitled.jpg (248.88 KiB) Viewed 414 times
- Untitled2.jpg (49.55 KiB) Viewed 414 times
- 20210812_170357a.jpg (138.33 KiB) Viewed 414 times
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
kevin
